hello all,
Just after some advice please?
Cold water tank in loft has started to leak, it is a metal tank, the old galvanised metal type..
It only seems to provide water to the hot water cylinder.
I feel quite capable of replacing the tank myself.
The tank of course has the 15mm cold feed, the overflow and what looks like a 28mm cold feed out to the hot water cylinder.
I don't paticulary wish to solder in the loft for obvious reasons, so was contemplating push fit connectors ? Or compression?
What would be the preferred method?
I value your comments.
Thank you as always.
