Of course when I go to use the multimeter (it's normally used twice a year) I've left it in the on position and the battery is flat. And of course I don't have any spare or rechargeable 9Vs in the house.To check contact
Set multimeter to ohms
Remove contact wires from control panel pcb.
Put multimeter onto wires ,with door closed you should get 2.2k reading .
With door open you should get 6.8k reading.
You can also do this from engineer utilities, view zone status.
This will show if door is open or closed.
Brilliant.
I have checked in Engineer Utils and it does show as Active though
