I have a large picture window in our front room 5.3 feet high by 7.5 foot wide. There are large areas of mist between the panes due to a leak in the sealant.
I saw an advert where the sealant could be repaired and the mist removed but digging around, it seems that this is not a solution.
I have just replaced a faulty boiler so it is now time to replace my window and have a few questions.
1. If the seal is broken, then I guess it makes the DG inefficient. Is there a significant amount of heat that will be lost through this window?
2. One glazier I spoke to said that this is an oversized window and the replacement cost would be high (~ £700) as the supplier would charge a 30% surcharge. Is this correct?
Thanks.
Thanks.
