I want to replace an old Honeywell room stat with a salus RT300RF. The problem is the salus manual says it requires a permanent live, neutral, common and switched live (NO). Ive checked the wiring at the Honeywell and I have 3 wires plus an earth comprising a timer live on connector 1 (not permanent..only comes live when the CH programmer is ON), neutral on connector 2 and switched live on connector 3. I want to keep the CH programmer controlling the overall on/off times not the room stat
Do in need a permanent live on the salus receiver or will a timer live do?..I was thinking Honeywell 1 timer live into the salus L, link L to common on the salus, Honeywell neutral into salus neutral and Honeywell switched live into salus NO...will this work?...if so will the salus receiver be able to cope with its 'permanent' live constantly going on and off as per the CH programmer settings?
the other option I thought was to run a new neutral and permanent live to the salus, connect the Honeywell timer live 1 into the salus common so that it will only switch live if the stat demands it AND the CH programmer is ON, plus the Honeywell switched live into the salus NO...will this work and give me the desired overall control via the CH programmer?
