Replace old thermostat with Drayton Wiser Kit 3
29 Aug 2022
Hi
I've recently planned to fit a Drayton wiser Kit 3. The actual controller seems fine to fit using the standard wall plate, however, i wanted to remove the old thermostats instead of turning them up fully.
Below is a photo of existing wiring on the thermostat, there are three wires. Can someone tell me which wires I can connect together to effectively discontinue this thermostat. I don't want to open the wiring centre etc, i prefer to make the changes at the thermostat end.
Photo of Thermostat wiring
Any help is appreciated
Many thanks,
Join Black and Brown and safely isolate the blue
If posting again and you want to add pics simply click the attach files on the bottom left of your post, the pic will then be part of the post without re-directing
