Replace outside plug socket+problem in mcb in consumer unit
23 Jan 2011
Lancashire
Hello All
Moving into a new house and I've two problems.
Problem 1
There is a double outside plug socket fitted that needs replacing. Should I replace it with a socket that has build in rcd's or replace it with a standard non-rcd socket?
Background: The sockets don't have a built in RCD. They look like when the house was re-wired in 2006 the outside socket was added to the kichen socket ring that is protected by an mcb in the consumer unit. Is that why the outside socket has no rcd built in, as the consumer unit is the failsafe?
Problem 2
The bathroom as a spa bath fitted. The bath has it's own mcb in the consumer unit. The mcb was tripped off when we moved in. It is difficult to trip the switch back up and when I manage it the coloured window stays green. There is no power going to the bath. Does that mean the mcb has failed and needs replacing or could it something more in depth?
thanks
There is a double outside plug socket fitted that needs replacing. Should I replace it with a socket that has build in rcd's or replace it with a standard non-rcd socket? ... Background: The sockets don't have a built in RCD. They look like when the house was re-wired in 2006 the outside socket was added to the kichen socket ring that is protected by an mcb in the consumer unit. Is that why the outside socket has no rcd built in, as the consumer unit is the failsafe?
It depends on whether the circuit supplying the socket already has RCD protection in your CU (with a 2006 re-wire, it may well have, but not for certain). If it does, then there is no need for an RCD socket - an ordinary non-RCD one (suitable for outside use) would be adequate.
The problem could be with the MCB, the bath or even the wiring. It would need to be looked into by an electrician - we can't guess.
Kind Regards, John
1) A non-RCD socket, as it's on an RCD protected circuit. I recommend MK Masterseal.
2) It could be a failed MCB, or it could be that there's a fault on the circuit which is stopping you from switching it back on. Will go to the On position with the main switch off? What's the rating of the MCB, and the load of the bath?
Is Specsavers open tomorrow?
I misread this
Thought he'd written RCD.
:oops:
Thanks for the answers.
would a picture of my consumer unit help to determine if there is any rcd procection? Just for my own interest. I know when the wife cleaned the grimy kitchen the kitchen electrics kept tripping the mcb and the mains switch (which I may wrongly assume is an rcd) as some water must have got behing the plug sockets.
To be honest on sensible reflection we are planning to rip out the whole kitchen this year so I'm thinking why spend money swapping the socket (it works, it's just the cover hinge that's broke and I use an rcd extension lead with it anyway) when the whole kitchen wiring will be ripped out and I can get a new outside socket fitted by a pro when the kitchen is fitted.
The same leccy can look at the spa bath at the same time as we've not felt the need to use it yet.
Even though, in view what you go on to say, the question may now be moot, a picture of the CU (showing any labels, if there are any) would certainly be a good start.
Kind Regards, John
Here's my consumer unit attached.
Seems the kitchen sockets and thus the outside plug are protected by an RCCB.
Does that negate the need for an rcd outside socket or would a belt and braces approach be prudent?
It is a good idea to fit a double pole isolator in the feed to any external socket so that in the event of damage / rain entry the damaged socket can be fully isolated so that the RCD is not tripped due to the external socket fault.
It also can be used to prevent un-authorised use of the external socket.
