- Joined
- 30 Oct 2006
- Messages
- 6,755
- Reaction score
- 386
- Country
Unfortunately, that's only renewing half of the contaminated valve seat/seal assembly - a quick fix that may not work.
out of the hundreds of these i must have changed ive never had a problem. you do clean the brass seat don't you?
gasguru said:I suggest you replace the complete PRV.....unless you are familiar with the valve construction and removal technique it is very easy to to screw up the pressure calibration since the factory adjustment is not threadlocked.
i will admit however for a novice that could happen.
