Replace Smoke Alarms without setting off Security Alarm
Status
Not open for further replies.
13 Nov 2019
Warwickshire
The smoke alarms in my house are completely knackered and need to be replaced, so I bought two Aico EI141RC alarms with mains and battery back up. I now need to fit them. Step 1: turn off breaker on DB so I can wire the new alarms without getting electrocuted. The problem is my smoke alarm and security alarm are on the same breaker, and when I turn it off, my security alarm thinks the power has gone out and sets off an air-raid siren.
The security alarm is a 12 year old Gardtec, I think model 370 581/582. I opened the security control board (which set off the klaxon again) and disconnected the battery in there, but the siren carried on going so there must be another battery somewhere. Is there a more graceful way of disabling the alarm without taking a 4 lb hammer to the siren itself?
As above, the alarm should not sound if you disconnect the power the back up battery should take over so yours is clearly in need of being replaced.
There is also a battery in the siren which is why it kept going when you disconnected the back up battery.
Make a note of the ah and dimensions of your back up battery and buy one of the same size
Thanks both. I was hoping not to have to buy a battery, because the security alarm is rubbish and needs to be replaced, but I don't have money for that now. Guess I'll look for a cheap battery on eBay.
According to the manual a 12v 1.2ah will fit happily , quick look on eBay tells me there's one for £5.65 which is pretty reasonable
The security alarm control panel display is cryptic to the point of being unusable unless you have the manual directly in front of you, and even then it's complicated. The symbols look like something out of the Predator films... Maybe it's just because of it's age, because my mum had a new alarm installed a couple years ago and her controls are actually in English. You don't have to try and guess whether ≡┣ means you're removing a zone from the alarm, or launching a nuke at Mars ;)
Good thing is if your cabling , bell box, pirs and door sensors are all ok then it's not too difficult nor expensive to replace the panel and keypad
Status
