Replaceing manual thermostat
25 May 2008
Surrey
Hi everyone,
I have an old thermostat a Drayton 533 & I want to replace it with a new digital one. so could someone point me in the right direction on how to fit the new unit.
On the mechanical thermostat I have 3 wires connect to the unit.
The blue wire connects to the connector labeled N, which i assume is neutral.
then I have a red wire which connects to the connector labeled L, which i assume is live.
Then i have a yellow cable which connects to the connector labeled Heating load.
on the Digital thermostat I have 3 connectors.
LX = Common
L1 = Live feed to the item to be controlled.
L2 = Changeover contact
So which wire connects to which?
Thanks in advance
Glyn
PS. I have a combi boiler if that has any relevance
presume digital stat has batteries to power it. red to LX. yellow toL1.
make blue electrically safe not required, turn off juice :shock:
wow thanks for the fast reply, yes the unit does have a battery to power it, just a quick question so why dont i need to use the blue wire? on the new thermostat?
Glyn
blue wire [neutral] is required on most room stats [except gas bellows type] to power an anticipator. not required on battery powered digi stat as batts supply power to timer/sensor. digi stat is a batt operated switch that provides on/off signal to boiler ch terminals.[remember 230v at LX L1] :D
wow thanks again paulybaby, followed your instructions all worked well.
a big thanks to you m8 :)
cheers
Glyn.
