replacement door frame - where to buy?
4 Jul 2009
Devon
I need to replace an internal door frame, however the existing one currently has a fan light above. I would like to keep the fan light to keep it the same as the existing doors, so in total the frame is 2.3m high. The only frames I have been able to find are 2.1m high. can anyone suggest where I can get a standard pine frame?
Jeff
can you not make your own up out of planed timber to the size you require?
You need a lining or casing - not a frame :wink:
A proper timber or builders merchant should stock individual lining sections up to 2.4m long, from which you can make your own
