Replacement Inspection Chamber Cover
18 May 2011
Suffolk
Hi
Had a skip delivered Friday and forgot to protect the inspection chamber cover....cracked lid but no drain damage
I have a plastic Osma inspection cover which is screwed down. It is 500mm x 500mm, the top of the riser below is 480mm wide and the drain 450mm wide. It is on a tarmac drive.
Cant afford Osma replacement, what is the best alternative. Can i get away with a 600mm x 450mm lid or do I need a 600mm x 600mm. Best place to go to please.
Many thanks
