Not sure which is the right section for this query because it concerns various specialities but hopefully someone can help:
I have a five-ring gas hob that I want to replace with an induction hob of similar size. The first issue is the capacity of the cabling for the existing oven, which I think will need to be upgraded if adding an induction hob. The replacement hob needs a bigger cutout than the gas one, and the worktop is quartz. The gas hob needs to be disconnected/removed and then the electric one installed, after enlarging the cutout and upgrading the wiring. So my question is: Would I be able to find a tradesperson to do all of this or, worst case, do I need a gas fitter to remove the old hob, someone else to cut the quartz, and a third person to do the electrics and fit the new one? Bearing in mind it would be very inconvenient to be without a cooker for more than a day or two.
Thanks for any suggestions.
