corgiman said:Thats is the most stupid question ever
how long is a piece of string
corgiman said:Dam good reply
shocking said:Hi David
Yes. It is a straight swap but the old one is imperial size so miner alterations are needed.
I have drained down as it was leaking badly
I have been quoted £230.00
benjamin31 said:I charged £165 for supply and installation of a 1400mm x 600mm singe panel rad with a drayton TRV. Took 4 hours to drain system fit rad, and fill back up and bleed, test etc.
I'm in the midlands, so probably not quite what you'd pay in London. Also depends what quality radiator your plumber is supplying.
gas4you said:£165 wouldn't even cover labour for 4 hours let alone entire job![]()
Bahco said:gas4you said:£165 wouldn't even cover labour for 4 hours let alone entire job![]()
£165 is pushing it a bit Dave, for 4 hrs work![]()
