Hi again
Had another company around tonight. The guy that came around is a gas-safe engineer.
He was very much trying to sell us lots of different types of work which may need done and I told him what has happened to date.
He asked if all radiators except for problem rad get hot. We said yes. Also, told him about draining off water. He doesn't think that we have a blockage in the pipes especially when there is not alot of water discolouration.
He said that the pipework may not be piped right, ie piped upstairs to come back down to feed a rad. I don't think this is the case, looks like a manifold upstairs and downstairs with flow and return pipe running up inside of cupboards to the upstairs.
He then said that the modulating thing was rubbish and that he was the one that needed to worry about the boiler modulating. He explained that the boiler runs on a high flame for DHW and a low flame for the CH.
We originally asked them in to provide a quote for the repiping of the rad and drain valves.
He said that he would recommend the following and will quote for these:-
1. repipe the big rad in 15mm plastic pipe, with copper sticking out the floor (so that we don't need to take up too many floorboards).
2. Fit the drain valves(my request).
3. Provide a quote for a new boiler.
He thinks that the heat exchanger may have went on the boiler - but he had no basis for this. If this has happened, he said that there would not be much difference labour wise between fitting the boiler or fitting a new heat exchanger (4hrs + £400 for the exchanger or 8hrs to fit a new boiler). We would therefore have the additional expense only on top of this for the new boiler. Boiler will be a WB 28i junior condensing around £1800 with hot flush and change to pipework to boiler.
We then said that we would probably get the rad repiped and the drain valves fitted first, and if this didn't improve matter, possibly get the boiler replaced.
He said that this would be an awful expense as we would be paying for him to drain the system down twice. He thought we should get the repipe and boiler done at the same time. I didn't think much time was involved in draining the system.
I asked if we would need to get a powerflush done for the warranty on the new boiler (it will be a worcester bosch condensing boiler). He said not necessary and they would do a hot flush with some cleaner in the system.
I was not any further forward from the conversation other than the guy trying to get me to spend a few thousand on a boiler that he could not provide didn't work.
I then phoned the Alpha technical department.
The guy told me the following:
1. He thinks the boiler is working correctly.
2. He said that the boiler works at 80% efficiency and the hot water needs to be taken away from the boiler quickly enough. He said that the microbore is probably not up to the job and recommended that it was probably better to repipe the whole house in 15mm and this will allow the boiler to work better.
3. As a minimum, he said that I should first try repiping the problem rad to see if this takes the water away quick enough.
At the moment I have the option of fit a new boiler or repipe the system but the boiler may still not work properly.
The alpha guy also said that I will probably need to repipe the whole system in 15mm anyway as condensing boilers work at a lower temperature and the pump needs to pump quicker to get the hot water to the rads quicker. So I may need a complete new system.
So fed up now. At least my husband experience first hand the conflicting reports for the plumbers and we are non the wiser.
My boss thought it may be a faulty diverter valve. He asked me to turn on the hot tap with the heating off to see how much water flows before the boiler cuts in and then turn it back until the boiler goes off, but water still coming out of hot tap. Then turn the heating on and see if the heating comes on and the hot water tap gets hot. When I did this, there was water going down the CH flow pipe and the water from the tap heated up abit at the same time. The plumber that came this afternoon said that this proves nothing and that the diverter valve is not faulty.
Is what he said correct?
fluff
