Replacement Thermostat
9 Apr 2016
Is anyone able to advise on a direct replacement for a Satchwell TLX 2251?
Or even an upgrade? Its currently used for a Myson/Thorn 25/30ah WAU
Just putting it out there but would a NEST work? What are my options?
Thanks for your reply! Will any 24v thermostat work? I'm just after something which looks like it's from this century.
A direct replacement is the same item, available here: https://www.tlc-direct.co.uk/Products/SATLX2251.html
As it's a 24 volt device, you can forget about Nest and most other thermostats unless you want a non-trivial amount of rewiring.
What?????
If there's wires there then a nest would work yes.
I would abide not diying it though.
Search this forum for "how to connect nest" unless you have a good understanding of hygiene control wiring it's not an easy job
If you want Nest it should be simple for a trained installer to make the switch
That's great thanks for all the help! If we don't go for a nest will any 24v thermostat work?
