Replacing 12v AC halogen light with 24V DC transformer
10 Jun 2012
Yorkshire
Our house was built back in 2013 and one of the cupboards in the kitchen was fitted with a 12v AC halogen light and transformer controlled via a wall switch. It is only supplied with a brown/blue cable from the wall. I wish to replace it with a transformer to power some hue lights that requires 24v DC. I purchased a "kit" off ebay to do this, but it advises using a junction box before the transformer as that is the current regs?
Before I go out and buy one to fit, which I don't mind doing, is this really needed? Having only been fitted 6 years ago without a junction and its a direct swap. If so, I'd be interested to know the reason why its now part of the regs :cool:
Oh and I'm assuming this would be adequate for the job: https://www.screwfix.com/p/5a-4-terminal-standard-junction-box-white/8906d
Thanks for the reply. No cable fitted, just the usual 2 AC 240v in and 2 DC 24v out. A cable was supplied to connect on the DC side with the correct fitting for the hue controller box.
^ the current transformer, I was just going to swap it in place. If its safer/better to add a junction I will do so.
