Replacing a ceiling light with a socket?
12 Jan 2006
I would like to create a socket to use in my loft, there are no existing sockets in the loft but a number of cables run through the joists for 1st floor, 240v ceiling lights, one of these lights is never used so I would like to know, if I kill the electricity can I disconnect the cable which runs to this redundant light and simply wire this straight into a pre-bought, unfixed socket, many thanks.
yugnoj said:
:o Good God No!!!
My Advise To You Is ....Call An Electrician
yugnoj said:
if the socket is only for something like an TV amplifier or similar, then you could, but be aware that power from the socket is very limited. 5 or 6A including all lights
but some one will want to plug some thing else into it.
NuttallsSpark, i agree with you, but it was andy i quoted, not you
at which point they'll trip out the breaker on the lighting cuircuit and if they have half a brain hopefully realise whats going on.
i see putting 13A sockets on lighting cuircuits as no worse than selling extention leads with a 5A fused plug and flex to match.
i wouldn't do it if the sockets in a normal location though only if the sockets fairly inaccessible (behind equipment in the loft near the ceiling etc).
if they are stupid enough to do as you suggest, then they will also be too stupid to realise what they have done is the cause of the problem, since if they could figure it out, they would have realised you cant do it in the first place
why is it daft to put awkward to access (so unlikely to get used for a hoover etc) sockets on a lighting cuircuit. i'd much rather any lamps i own have standard plugs that can be used anywhere and yet still have central switching availible.
If it is to run a loft light then install one properly as part of the upstairs lighitn circuit. If it is to run the TV amp etc. a Fused Connection Unit with a 3A fuse & a socketoutlet aren't going to cause any problems....... unless you've got a bathroom extractor fan already on that circuit. These can induce interference on your TV amp, as can the hoover or boiler ignition if you power from the ring.
BAS is correct that there is no specific regulation preventing the installation of a BS1363 socket outlet into a dedicated lighting circuit, I would strongly urge against this action for many of the reasons posted above.
TV amps can be a problem, and to be honest they are better on their own dedicated circuit, however if this is NOT an option, then I would suggest the installation of a 5A BS196 round pin socket and replace the plug on the equipment ot be used to a BS196 5A plug. These are designed for use on lighting circuits, and they will prevent the use of "standard" equipment in the socket thus removing the risk that someone will plug in high load equipment that could trip the circuit.
The BS196 plugs are available in two types, fused and unfused. Generally the unfused is what will be available, but if you can get a fused one, then I would suugest this and fit a 2A fuse into it. Should anything go wrong with the amp then it will not affect the lighting.
