I am very much new to plumbing, so far my experience has been in unblocking a few u-bends and plumbing in a dish washer with a self cutting extract pipe.....
I had a problem with my combi boiler... A worcester 35CDI.... It had been losing pressure regularily and needing to be reset multiple times daily... From browsing here and doing a bit of fault finding I found it was 99% likely to be the pressure release valve. The pipe from the PRV is warm so I suspect it is letting, although I cannot physically see the water as it is plumbed into a waste pipe I believe....
Anyway, I purchased a new valve, and was going to attempt to replace it, but the connection to the copper "waste" pipe (the pipe from the PRV to outside) is stiff and unable to be removed... It's brass, so obviously rather soft... My question is what tool should I use for this... I have an adjustable which seems to be too hard, and damaging the brass.... and I have some pipe grips but I cannot get the purchase on it I need....
Thanks for any help, and as this is my first post... Hi...
