Hello. I am replacing an old Landis & Gyr room thermostat with a Drayton RTS1. The current wiring on the old stat is red, black and blue. Red is live, The blue is wired into the earth position, so I presume that in this set up the black wire is neutral.
Our new Drayton is double insulated so the instructions say no earthing is necessary. However this model needs a wire to a 'call for heat' signal. Should I use the blue or black wire?
Thanks.
Thanks.
