I am going to replace my towel radiator with a vertical one which is the same size and has the same width between the pipes but gives out more heat. It fixes in much the same way as a towel radiator.
Will I have to drain the system down or can I get away without having to do this.
I have read that it is hard to take towel radiators off without doing so and also that if replacing with a different type the system has to be drained.
