Replacing a Turbomax plus 824e diverter valve..
5 Mar 2009
Northamptonshire
Hello again chaps. I have received my new diverter valve(with the bigger holes) and am considering fitting it myself? From what i have read on previous posts it doesnt seem too bad a job,its certainly easy to get to...
At the risk of sounding like an idiot and asking you to go over something that you have probably already covered a million times? Is it just a case of turning the water off at the main stopcock,undoing the old valve and letting the water drain into a bowl,fit the new one and the turn the water back on at the stopcock and the refill the boiler by turning the key underneath and then bleeding the rads? Cant be quite that simple can it? :?
At the risk of sounding unhelpful, this has already been explained many times on this forum.
I have got boilers to go and fix so could you do a little searching and you will find it.
