Replacing analogue roomstat with Honeywell CM907; wiring?
16 May 2005
Surrey
I want to replace my dial-type Eberle roomstat with a CM907 that I've just bought.
The CM907 just requires simple Live & Neutral connections. However, I took off the front of the Eberle and it had 4 connections; Live, Earth and two Neutrals (one N was something to do with a "heating load").
Can someone please tell me what I need to do with the wiring? Do the Earth and Neutral (Heating Load) wires become redundant, or do I put the two N's into the same connection block on the CM907? Cheers.
Boiler is a Baxi Barcelona system boiler and the CH/HW timer is a ChannelPlusXL H27 (on which the CH timing will become redundant as I'll just leave it to "On").
the cm907 is battery operated wireless system right?
does it not come in 2 parts?
are you sure it doesnt have batteries? under the flap at the bottom
Thanks.
Yes, it has two batteries.
Sorry to be dim; I know to connect old 1 to new A, but I'm still not clear what wire to put in new B. There isn't a 3 on the old unit, it has 1, 2, E & 4.
Okay; I'm going to connect Live (red wire) into Terminal A and the Switched Live (yellow sleeve) into Terminal B. May the force be with me.
Electrically incompetent might be a fairer self appraisal. Look at the wiring instructions that came with the unit. If you don't understand these or the way a standard 240V r/stat connects then wiring by proxy might prove difficult.
[/quote]
Sounds promising.
that should be right, but boy do you live dangerously, please be careful!
Installed it today. Only took 5mins. Lovely bit of kit.
Many thanks for the help.
