Replacing bathroom radiator with heated towel rail.
22 Oct 2010
Hampshire
Hi!
I'm interested in swapping my bathroom radiator for a heated towel rail for convenience. At the same time i would be looking to increase the heat output so was thinking of a 5ft or so towel rail. Is the increase in size likely to cause any problems to the boiler? I appreciate there are plenty of variables in that question :)
Am i able to connect up the towel rail using flexible braided connectors or must it be copper pipe as i feel the existing pipework may not line up correctly.
I appreciate your time, thanks for any help/advice you can offer!
Mike
There should be no problem unless you have an open vent system and the top of the new rail is less than 800mm from the level of the F/E tank. Braided hoses are not suitable, they are perishable, intended for H/C water supplies and will also look sh*t (if that matters).
Thanks for your reply Tibbot!
Your right about the braided hoses, they would look pretty bad. I did think about this after i posted. Laziness was getting the better of me as usual :oops:
Im glad that there is no obvious problem to doing this and, when funds allow, think i shall get my arse in gear and get it done :)
Thanks again !
