Hi all
In the process of purchasing a property to let out with a back boiler. While jm doing other work to the house I thought about changing the back boiler to a wall mounted boiler that is easier to fix and obtain parts, plus easier for tenanted property
Can anyone recommend a decent heat only boiler?
Once I have decided on boiler, will get a gas fitter around to do the removal/fitting. Hoping I can use all other fittings etc
Also am I am to keep the gas fire it currently has or would I need to replace with a new gas fire?
