    Dismiss Notice
Replacing built in oven
Discussion in 'Electrics UK' started by Thomas Parkinson, 26 Oct 2019.
  1. Thomas Parkinson
    Thomas Parkinson
    26 Oct 2019
    Thanks Received:
    Country:
    I've bought a new oven and had the previous one removed. The old oven was plugged into into a 45 amp dual pole socket/switch along with a hob that is hard wired.
    Problem is the old oven has a wired plug that went through a tiny hole the from oven cavity to the socket . The new one has a moulded plug.
    The hob is wired into a 30A junction box that goes to the dp switch.
    Should I bore a hole big enough for the plug from the oven unit into the adjoining one? Would this be ok with the heat given off by the oven?
    Or can I strip the plug and wire it into the 30A junction box along with the hub?
  2. Sponsored Links
  3. DetlefSchmitz
    DetlefSchmitz
    17 Aug 2010
    2,045
    Thanks Received:
    262
    Country:
    Either this, or remove plug, thread wire through, and fit a new plug.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
