I'm about to replace my cracked ceramic hob with an induction hob and wondered if there could be any issues with power.
The ceramic hob shows
Voltage: 230V 50Hz
Supply connection: 30A (double pole switched fused outlet with 3mm contact gap)
Max Rated Inputs: 5.80kW
Mains Supply lead: 3 core x 6mm
The induction hob shows
Voltage: 230V
Current: 29
Max Power W: 6.6kW
Electrical cable: 3 x 2.5mm2
Is there going to be a problem (i.e. is this going to cost me loadsa money to get installed?) or is it going to merely be a case of switching them over?
Sorry, I'm clueless, I know! ;o)
Voltage: 230V 50Hz
Voltage: 230V
Current: 29
Max Power W: 6.6kW
