Hello,
Looking for some opinions about how to go about my job for the weekend. I already bought all the bits in October, then my daughter was born and I never got around to it.
Our galvanised cold water tank has a slow leak and I'm replacing it with a plastic coffin type. Initially, I thought it was supported on the beams by planks of wood and some wedges to level it up, but on closer inspection I see that underneath there is a metal bracket, pictures attached. I'm unable to see clearly but it looks like they are set into the wall and I'm wondering if possibly even counterbalanced on the other side by the neighbour's water tank.
So my first question is - how likely is that? And second question, what happens when I remove the tank?
I have bought a sheet of 18mm ply as a base which I originally planned to support using 10cm fence posts over several of the beams (at least 3) to spread the load. The reason for fence posts is to bring the beams level with the larger joist that runs perpendicular (see pics). I'm now thinking the beams won't support the weight of the new tank (plus the old tank still left to one side), and those metal brackets should be used somehow. This would be fine if the tank was the same size and shape but nowadays tanks are long and thin so it would be quite off balanced.
How should I support the new tank? Should I try to use the old bracket? Grind it off?
