Replacing External Bell Box on Honeywell Accenta G3/G4?
9 Nov 2010
Cheshire
I am trying to help my elderly neighbour make good his old alarm system whilst doing some work on our semi detached houses. The system appears to be a Honeywell Accenta variation - quite odd, as the case appears to be from a Challenger G4 (outside label just has "Challenger" on it), but the board inside is very much a Honeywell Accenta G3 from what i've found out - bit of a frankenstein as the RKP seems to be from an Accenta G4 (He did say someone replaced the faulty keypad for him some time ago).
The outside bell box was the 30-40 year old large rectangular variety, with a basic siren and a strobe connected directly to the BELL+/- and STROBE+/- at the control panel (as the attached photos show). Thinking this was a Challenger controller, I purchased a Challenger AU1000WBX universal bell box and sounder, but that obviously didn't work as the power through the BELL+/- or STROBE +/- is disabled when the alarm is disarmed, meaning the device constantly goes through the delay startup sequence at every activation!
After some research (read google and engineer manuals!) I moved the Bell +/- to the 13v output +/- terminals, and connected one of the other 2 wires to BELL- and the other to STROBE-, connecting them to 12v +/- in the bell box, and to Trig- and STRB- respectively. Alarm box now arms and stays on after a code is entered, but after the 2 minute delay the siren goes off and (but not strobe oddly) - alarm panel shows everything normal and disarmed. From what i can gather and measure with a multimeter, when the alarm is armed and going off, the output from the Bell/STROBE- controller terminals tie down to 0v so i get full voltage between the 13v output+ and the - terminals for the BELL/STROBE; as soon as it's disarmed, this voltage drops to 0v, i assume because it then floats?
I can't see any way to program or change a jumper or wiring in this old unit so the trigger 0v is inverted and i don't think this alarm has a programmable option to change it. My neighbour can't afford to replace it (he's 85) so i want to try and get this working for him if i can.
Is there any way to change the trigger behaviour on the controller so it responds the way the AU1000WBX is expecting? it was suggested to force it high by adding a 47K resistor between +/- terminals of BELL and STROBE so it might behave in a way the bell box expects, but not sure if thats the right approach - can anyone please help?
Thank You!
So what do you want to do exactly?
The bell box looks like power and bell trigger and strobe trigger are wired. But tamper return isn’t wired.
The panel looks like the wiring is different for the bell to the bell itself!
So you have two wires to bell from the panel and one set for strobe.
But looks like the strobe +- are wired to bell trigger and strobe trigger so don’t quite add up.
But had a few beers so may take another look later
Thanks for replying!
Basically i've removed the old bell box that contained a direct wired siren and direct wired strobe, and want to replace it with the AU1000WBX instead. I just don't know how to wire it to work - i assume the new bell box is needing a different signal to the one being sent by the - terminals on Bell and Strobe? There are only 4 wires going to the bell box from the controller, so the tamper lines can't be connected (which isn't really a problem I guess as the box has internal tamper anyway). Am I right connecting directly to the 13v output terminals for the power for the bell box or do i need to wire using one of the strobe or bell + terminals?
hopefully this diagram helps - top is how the original setup was wired, bottom is how i last tested with the new bell box; with this wiring the box stayed powered after disarming the system, but after the 2min engineer delay it went off and couldn't be disabled via the keypad (and no errors on panel). For info, when i wired it the first tim, i wired bell+/- to the 12v input and strobe- to the strb-, adding a loop wire between strb- and trig- (in bell box). this resulted in the bell box starting the provisioning delay every time the alarm was triggered, with the power completely disconnecting after it was disarmed - hence the changed connections as per the second image!
Thanks for that; being stupid can you confirm i'm right on my understanding?
Controller---------------------------- Bell Box
D (Bell +)---------------->------------ Supply 12v+
A (SCB)------------------>------------ Supply 0v
B (Bell -)----------------->------------ Trig- (Bell)
S (Strobe -)-------------->------------ Strb- (Strobe)
Does connecting to A mean i need to remove the shorting link between T & A on the controller?
I only have 4 wires running to the bell box so can’t connect the return as well unless I loop strobe- and bell- at the bell box and then I can use the spare for return- instead?
