Replacing Garage Up & Over door with a UPVC unit, need advice please.
2 Jan 2015
London
I'd really appreciate some advice on this please.
Our Garage (now an approved store room only) is connected to the side of our house, has it's own flat roof and supporting lintel above the front up & over door.
It is not and will never be part of the habitable zone of the house, it will remain unheated and used just for storage as it has done for years. We are also not in a conservation area.
I'd like to remove the up & over door as it's too heavy for my Wife to lift and replace the opening with a full UPVC wide unit on a 150mm / 200mm plinth (Option.2) or brick part of it up and have a French door on the left and a window on the right (Option.1).
UPVC frames type & colour will match those already fitted to the property.
It would be great to do this under Permitted Development and not requiring Building Control intervention but I'm unsure if this is possible.
I think it may qualify under PD, but not sure about Building Control, not sure which option below is more favourable.
The garage opening width is 350cm and the height 240cm.
Here are the example images, thanks in advance for any help you can give.
Our Garage is connected to the side of our house, has it's own flat roof and supporting lintel above the front up & over door.
Permitted development and Building Control are not the same body or mutually exclusive.
If you are preventing further use of the garage as a parking space, then you may fall foul of Planning (permitted development etc), who may bump their gums at you for having x amount of occupants but only y amount of parking space.
Building Control may want to see toughened glass in the frames.
I don't understand the plinth in the second image...? :confused:
Hi Noseall
The Garage (as we call it) is actually no longer a garage as when the property was previously developed 5 years ago. It was divided with the rear section becoming a utility room, sectioned off completely and become part of the habitable house. The front part of the Garage is a dedicated store room, only accessible from the up & over door. So it was previously already approved as a store room only and it is shown on the plans.
Yes the Glass will have safety certification.
As for parking, we don't have a car, never have and you could most likely fit `30 cars on our drive, lol!
Can you help me further regarding my enquiry?
Sorry yes, the image is crap i will agree, AI generated of course :rolleyes:.
So the plinth is just two tiers of blocks mounted on their sides from foundation level, DPC will be in these blocks and they are there for the UPVC frame to sit on. The DPC height will match the other DPC level around the house.
Yeah, crack on. (y)
Oh I'd very much love to, lol!
Being an experienced commentator and giving good advice which i've seen from you before whilst searching the forums, could i please have your thoughts on the PD and separate building control situation based on the two options i gave.
OPTION.1
Bricking up the middle, putting a French Door on the left and on the right brick up half way and fit a UPVC window.
Now this option requires partly bricking up the space.
OPTION.2
Fit a full width UPVC unit, French Doors in the middle with glazing to the left of the right.
This does not require any bricking up of any kind, apart from a small 150mm block plinth for the UPVC unit to sit on.
I will be obtaining a safety certificate with all UPVC units.
I'd really appreciate your opinion of both options outlining your thoughts on PD & BC.
This is the preferred design, remove up and over door and bung this in it's place :
Thanks in advance :)
