I am in the process of replacing an old imperial radiator (I asked some advice on another thread regards which type to get)
I went for a Quinnn Round top in the end. Obviously the new rad is a bit shorter than the imperial size one, so I have a couple of valve extensions.
One valve has a modern 15mm TRV fitted, but the other valve is still the old 1/2" (I think) fitting. I need to go from 1/2" Male (Valve) to 15mm Female (Extension piece)
I've tried looking around online but nowhere seems to stock anything like that. I know I ought really just replace the valve (and probably relocate the pipes coming up through the floor) but at the moment I just need a quick fix without the hassle of draining the system.
