I'm after replacing an old imperial sized radiator in the bathroom. Its 25" (680mm) wide.
Looking through previous posts, the simplest solution is to use a 600mm wide rad with two 40mm extentions.
The two valves at each end look fine and I'd rather keep them than have to remove them and fit new ones to the copper pipes as they are covered in paint (the pipes). My question is that with the old imperial valves, are they there 'same' size to fit the extensions?
