Hi. I'm replacing some internal doors and doing the whole lot, frames and all. Picture of the top of the rough opening for one is below. Are internal doors meant to have lintels? Only I don't see one...are they something you would see in this case? I've run a stud metal detector thing over the area and there is stuff there, but it could just be the wire mesh type stuff they use around doorways to stabilise the plaster. This is in a structural wall which is made of grey breeze block type material, though it appears to have bricks above the opening. If it helps it's a ground floor purpose built flat (1973). It appears to be perfectly stable as far as I can tell. I've built another door frame and was going to put it in place & pack above the frame like you pack the jambs.
cheers
View media item 31845
cheers
