In order to install a new bedroom ceiling light, I've taken apart the existing ceiling rose and don't quite understand what I see. The wiring doesn't seem to correspond with wiring examples that I've seen on here and other sites.
Here's the existing wiring:
A couple of questions:
1) Is this normal, or anything I need to be concerned about?
2) I'm replacing this with a new light fitting which needs an earth, neutral and switched live supply. I assume my best option is to rewire what's in the image using connector blocks in the loft space above and then feeding a single 3 way cable through the ceiling space?
