I'm in an apartment that was converted probably in the 1960s. The meter tails go down two floors and I think they are probably 7/.064. Now I want to change my gas cooker for an electric one. As we have gas CH and no electric showers I think I could get away with it on capacity. But, I also want to replace the 1970s fusebox with a modern CU. I know replacing the tails will be a difficult and expensive job as they go through the other apartment, but it seems the right thing to do when I am having other work done.
So, if I dig into my wallet and do it, what size? Should I, or must I, go to a size that will run a heat pump? Even though at present there is no way to fit one in the apartment?
And should I take account of the size of the incoming supply? I don't know what it is, but I'm pretty sure that one supply runs two apartments each with two floors and to my knowledge has not been changed since 1974, maybe even earlier.
I have a background in electronics so I have a basic understanding, but obviously I need an electrician for this work. I will of course take a professional's advice but it would be very useful to have some ideas before I start discussions with tradespeople.
