Dear All,
I currently have a module grid switch in my kitchen feeding four appliances; a fridge, dishwasher, fan, and hob.
Each of the four individual switches is rated to 20AMP.
The feed from each switch terminates at a single switched plug socket under the worktop.
I would like to update the switch to a modern version, i.e the click range from Scolmore.
On their website they manufacture both a 10AX and 20AX switch. The 20AX switch is double the size and only allows three switches to be fitted into the plate (I need four).
The 10AX switch version will allow me to fit 6 switches (I can blank off two).
Do I have to use a 20AX or 10AX switch? Scolmore sell both a 10AX and 20AX with appliances names written on them. I assume the 20AX would be if you were running more than one oven?
Can someone advise please?
Thankyou
Thankyou
