hi all, in the middle of fitting a new kitchen. got to the sink unit, want to do a better job than the previous owner who has cut a groove from the end of the base to the centre to slide the unit in because the main water line with stopcock somehow just comes up from the ground smack in the middle of the sink unit.
will i be able to disconnect the waterworks from the stopcock and connect a flexipipe, so i can place the stopcock beneath the unit and use the flexipipe to reconnect it back to the waterworks from behind the base of the base unit?
is there a specific type of piping i need to use ( seen some kind that is not suitable for drinking water and some are wat does this mean?) so i don't contaminate the main water supply? maybe stupid question, but i think there is a chance of this if u use a bathroom tap in a kitchen instead of a proper kitchen tap.
should have found this site earlier. may have to go in blindly, dreading the earth wiring. will turn off mains first, just in case. i'll turn it back on once everything is connected back up. will be great to get any sort of advice on topic. thank you.
