First post but been trawling the forum for ages with interest.
We bought and renovated our house 10 years ago and got central heating system with Saunier Duval 30e combi put in. We now have to run taps at a trickle to get water hot enough for a bath although the central heating is fine.
We're about to have an extension and are planning to replace boiler with either a WB 37cdi or Vaillant 837.
The current boiler is in an airing cupboard in the middle of the first floor and is flued straight up through the loft and pitched roof. Have read your comments and views on the 2 boilers mentioned above, I've found out we can't use the existing flue system for a new boiler so will need to buy all new. My question really is about draining the condensate and a room thermostat.
Our current combi has no room thermostat, we have thermostatic valves on all the rads instead. Husband has 16th edition so could sort the wiring etc out for that or is that something a Gas safe engineer has to do? Or would it be better going the wireless route? The house will be torn apart anyway (god help me) so not too concerned about decorating/plastering etc.
Since our current combi insn't condensing we have no drain off. What we do have is a 15mm copper pipe running through the floor/walls, coming out near the back door over concrete - believe it's called a blow-off? This is just over a back patio area though, not a drain so could it be used? We could always put a gulley in there to link with rainwater drain as that's all coming up too (aagh!).
I know we should discuss this with engineer but in an effort to afford this extension we are doing a lot ourselves and we need to try and allocate budgets before we decide whether to go for a good boiler or a cheap one (we will probably sell in about 3 years) and we just need to know how much other work is needed apart from boiler swap.
I'd really appreciate any advice you can give.
Thanks in advance, Kirsten
