Hi, I'm in a victorian mid-terrace. General wiring seems to have been updated with no "rubber" wires left although a few of the old "bakerlite" type round switches are still here and I'm gradually changing them.
There's a two-floor outbuilding (brick built, used as a garage and previously some sort of office space upstairs in the 1970's perhaps) I have stripped it of all contents including wiring, rusty single CU and fixtures etc.
Power is supplied off the main house upstairs ring main from a junction box under the floorboards using 10mm PVC cable to the outside which is then suspended about 4m above ground, attached to a catinary (twine/rope type!) but it is failing and needs taking down.
Clearly I need to change... Can anyone help with advice on some specific questions? It feels like I've been browsing the net for weeks looking for the facts...
1. Is PVC cable as a replacement, with a properly installed metal cable catinary, unacceptable? Some seem to say it must be armoured cable, some say PVC is ok in this installation.
2. I'm pretty sure this should never have been done as a juncton from the ring main in the house. So I think it has to go back to the main house CU - a distance of about 30-35m total with about 20 being indoors.
3. Am I right thinking that I can't do the work due to part P reg's? Shame if not - I'm pretty confident on installing a few sockets and lights in that building, coming of a small CU inside it.
The idea is to put the tumble dryer in there (2.5KW), a freezer, a PC and an electric heater (3KW max). In addition to about 300W of lighting (there is the garage, a small room and the upstairs space)
4. Presently I have nothing running in there, the cable goes temporarily to a small MK fused spur box, running a small outside light. I think the building needs a small CU with 63A 30mA RCD main breaker, 3 MCBs - Outside light (6A?), inside lighting ring (6A?) and mains ring (40A?) - but I'm not certain I have those fuse sizes right yet.
5. If I can replace with PVC - or if I have to use SWA, would 10mm be sufficient, or do you think I need to go up to 16mm?
Any advice gratefully received!
The more I think about this the more it seems like it's more hassle to do myself and get signed off than to get a sparky in to do the lot (just more £££!)
Paul
Paul
