- Joined
- 31 Mar 2020
- Messages
- 3
- Reaction score
- 0
- Country
My set up is as follows:
Glow worm spacesaver mk2 boiler
Hot water tank with 2 motorised valves
Randall 4033 wired as per diagram
Thermostat in another room
I have read a lot of other 4033 replacement stories here but none seem to be wired like mine.
At present the HW and CH will only work together as there is no independent control on the 4033. From what I have read here, the presence of 2 motorised valves may mean independent control is possible with a new programmer. Most I have seen have the same 8 terminals like the 4033 but if I just map the connections using the wiring diagrams I presume I will still have no independent HW and CH control.
I am guessing that all I need to know is how the current wiring diagram would differ if the 4033 had independent HW and CH control. Once I know that I should be able to map the wires on a new programmer (what ever I decide to get). Any advice would be greatly appreciated
And on that subject of programmers any recommendations would also be appreciated
