Hi, An existing security light I have is in need of replacment due to heavy yellowing of the bowl and the polycarbonate beginning to crack at the base risking water ingress. The existing light is a 100W PIR Bulkhead, but has an extra PIR output terminal which we currently use to trigger a smaller 40W bulkhead used as a signal light which we can see from the living room. unfortuately, I have not been able to find a similar replacement with the added PIR output, can anyone help. I was wondering is there was a way to connect the signal light across the lamp terminals of the terminal block if a similar model is not available. Strangely though some lights say that the lamp can be 60W max which would do and that the PIR can switch up to 1500W, but doesn't mention how.
Thanks for any help in advance
