I am about to replace the fascia & soffit boards boards on my bungalow & have 2 queries:
1. At the eaves (i.e. just above the guttering) - I keep reading installation instructions that tell me to remove the first row of slates (well, the "modern" stuff) and fix new sarking felt (the end 300mm or so).
So, if I remove these slates, which seems to require using a tool to remove or break the nails, how do I re-fix them?
Alternatively, how do I fix the new sarking felt in place if I don't remove the tiles?
2. At the gable ends, there is a wooden fillet (c14mm thick) nailed into the top of the wooden fascia (all the way down, not just the final "kick") - the tiles are then nailed through the fillet and into the top edge of the fascia board.
How do I get the fascia boards off without damaging the tiles, and how should the tiles be fixed once I've replaced the fascia?
Neighbouring properties don't have this wooden fillet, but have a mortar filler (seems to be called a "cement verge"?). Is this the right way to do it? If so, where do the end set of tile nails go?
Any advice much appreciated!
