Replacing Thermostat
30 Sep 2014
Hertfordshire
Hi Guys,
Bit of a newby on this subject but my Honeywell T40 has just giving up (the dial has snapped) So I am looking to replace it with something a bit more modern and preferably digital. Any suggestions?
Also I have a box in the airing cupboard which I set to come on in the morning and evening then a T40 downstairs in the front room to adjust the temperature. If I replace the T40 with a programmable thermostat does that make the box in the airing cupboard redundant? If so do I need to take it out?
Thanks for the help
Tom
If you get a programmable Tstat, the timer upstairs is still usually required to control the hot water.
Any suggestions?
Just reputable make.
If I replace the T40 with a programmable thermostat does that make the box in the airing cupboard redundant?If so do I need to take it out?
Unless it controls anything else as well - hot water?
If not, you can remove it or set to permanently on.
ok, thanks for the quick replies!
It does control the hot water. So if I get a programmable thermostat I should leave the hot water on 'twice' and the heating on 'constant' then the thermostat downstairs will control when the heating comes on and goes off
Cheers again
