Replacing UPVC conservatory with wooden frame
28 Jan 2011
Manchester
I have a square shaped conservatory. The bottom third is a dwarf cavity wall and the then it has a standard upvc frame on top and a solid insulated roof.
Despite the roof, it's still too cold in the winter.
Would it be possible to remove the upvc frame and construct a wooden frame in its place? I woukd then osb and clad the outside, and insulate the inside and then board it - almost like SIPS panels..... I would have 1 large window on one side, French doors on the back where there currently are and one side would be solid as its up against neighbours fence. Just an idea.... wondering why it couldn't ir shouldn't be done......
Yes you could.
but the studwork frame would need breathable membrane externally then 50 x 25mm battens then the cladding material. The detailing of damp proofing and vapour barriers is key to a timber structure
it’s not ideal fitting framework with a roof in place, but I guess you could do a section at a time and use props where needed.
you might have a building regs issue as it would be an extension not a conservatory - depends whether you are concerned about that ( it could be an issue if you sell)
Thanks Notch. I'm guessing it's already 'an issue' because the roof is solid - so I suppose its already outside the classification of a conservatory.
