Repressurising boiler
22 Jan 2008
Hi - i don't know if anybody can help me... :confused: i am having a nightmare trying to repressurise my boiler. A Vokera Syntesi 25e. My filling valve is permanently connected so i did as my boiler instructions said to increase the boiler pressure and turned the filling loop to the vertically down position.
I expected to hear water entering the boiler and the pressure to rise but nothing happened. My central heatign system is working fine - all radiators and warm water nice and hot - so I dont know what the problem can be. My pressure is below 1 bar at the moment so would like to increase it.
The filling valve loop reaches from the filling valve (the one with the three normal/off/filling loop positions) along the loop to another tap on the left which has a black knob marked with open/shut in two directions. What is this and am i supposed to do anything with that?
Any help would be much appreciated :)
2 Nov 2005
Gloucestershire
most filling loops have a tap at both ends: both need to be open to fill the system... you are supposed to remove the filling loop once you have filled it, but no one does (including me).
Try opening both ans see what happens... don't fill past 1½ bar.
