Part P is nothing to do with notification.I thought that adding sockets and lights to existing circuits but not in kitchens and bathrooms was an explicit DIY exemption under Part P so that Local Authority Building Control do NOT need to be notified.
This is Part P:
it makes no mention of notification.
The exemptions are to do with notification, and have nothing to do with Part P.If that is correct, there would be no point making the exemptions if the CU has to be altered and notified.
Part P applies to ALL work on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are etc etc, not just notifiable work.
The exemptions from notification are not exemptions from the requirement to comply with P1, so if your chosen route to compliance with that is compliance with BS 7671:2008, and if the latter requires you to alter or replace the CU then that's what you have to do, because by extension the exemptions from the requirement to notify are not exemptions from the requirements of BS 7671:2008.
