- Joined
- 27 Nov 2026
- Messages
- 1
- Reaction score
- 0
- Country
After discovering a leak in our en-suite (in new built apartment block) I ripped off existing shower tray along with few rows of tiles from down up in order to get through the lining and to remove mould.
Now, I am in a predicament of what to do next to improve the current state of the walls and to make sure no mould will ever appear again.
By looking at the exposed areas - the back wall of the shower, which is the wall of a small bedroom on the other side, I assume the lining is next:
Studs (I assume one side is the bedroom wall, the other is en-suite), 20mm OSB board, 2 layers of plasterboard (grey - perhaps sound proof? and green - moisture resistant), tiles.
Same on the left side wall.
The right side wall, however, is slightly different: 20mm OSB board, 1 layer of plasterboard (grey), tiles.
I am considering ripping everything off down to the studs to gain some space to build a shower ledge (half-wall, attached to the stud wall, the top of which will be a wall wide shelf - not a niche - with a slop of course) and also potentially run pipes through it's cavity to change the current shower mixer's location to the back wall for easier access.
Although I'm lost which timber will be right for it:
1- https://mkm.com/product/38mm-x-75mm-rough-sawn-carcassing-green-treated-t000970 or
2 - https://mkm.com/product/47-x-50-45-x-45-fin-uc2-treated-premgrade-carcassing-t002831 or
3 - https://mkm.com/product/timber-cls-38mm-x-63mm-24m-vac-treated-t002945
This of course, means more work - moving the shower tray, changing the waste position, changing the shower position, etc.
The much bibber and more importnat question is: what about the walls new lining? It needs to comply with all the regulations: soundproof, fireproof, moisture proof. But I'm struggling to find any concrete information and also not AI generated nonsense. The only 2 things I came across were: for the shower enclosure - cement board or foam tile backer board, or board fully tanked; and - typical robust wall construction: timber (studs), 18mm plywood, 12.5mm plasterboard.
So here are options I came up with for the back wall with the half-wall/ledge:
Option 1:
- Fill the space in-between studs with acoustic mineral wool;
- 18mm Marine ply to the studs;
- 6mm jackoboard to the ply (or 10/12mm if it's necessary to re-create the original thickness);
- Tiles
Option 2:
- Remove only parts of OSB with mould;
- Patch with 20mm marine ply or 20mm new OSB;
- 6mm jackoboard to the OSB (or 10/12mm if it's necessary to re-create the original thickness);
- Tiles
Option 3:
- Remove parts OSB with mould;
- Patch with 20mm marine ply or 20 mm OSB;
- Soundproof plasterboard;
- Moisture resistant plasterboard;
- Tanking membrane;
- Tiles
For the side wall:
Option 1:
- 10mm jackoboard to the ply
- Tiles
Option 2:
- 10mm jackoboard to the OSB (or 10/12mm if it's necessary to re-create the original thickness);
- Tiles
Option 3:
- Tanking membrane;
- Tiles
Any advice would be appretiated!
Option 1:
- Tiles
Option 2:
- Tiles
Option 3:
- Tanking membrane;
- Tiles
For the side wall:
Option 1:
- Tiles
Option 2:
- Tiles
Option 3:
- Tanking membrane;
- Tiles
