Restoring Wooden floor
3 Mar 2010
Hampshire
We just bought our house and one of the first things we want to do is to remove the carpet and restore the wooden floor underneath which looks to be in quite a good condition. I am just wondering about which is the normal separation between planks that we need to have in order to have the wooden floor exposed. At the moment from what I have seen after lifting a few bits of the carpet there is about 1 to 1.5mm between planks which seems to be a lot.
Any recomendations?
Any recomendations?
normal gap should be zero
they should be fixed tight together
off course you cant clamp tight enough all the time to stop gaps appearing
So what is the normal process? shall I take them all off and put them back toghether closing down the gaps?in this case what happen with the dilatation?
Never seen floorboards laid without gaps , yours should be fine with such small gaps.
