Morning all
We are about to buy a property which has a retaining wall along one side which has failed. There is an alley down the side of the house for access to the garden and this separates the house from the wall by a distance of about 1 metre. The house is on the low side of the wall.
The house comes with responsibility for the wall as shown by a land registry report.
The wall is 1.6m high and runs for approximately 8 metres down the side of the garden then turns 90 degrees away from the house and runs for another 8 metres. The wall has failed at multiple points and a structural engineers report states it will need to be demolished and rebuilt with a concrete toe slab and hollow concrete reinforced, brick faced wall.
There is a road on the other side of the wall but separated by a patch of land approximately 2-3 metres.
I'm getting some quotes for the work, but should the replacement of this wall require notification to building control, or application for building regs?
One of the builders has also suggested it will require detailed drawings and calculations from the structural engineer.
This all seems a bit over kill for a replacement retaining wall, but I bow to those in the know.
