Retrofit cavity ties
9 Jun 2014
Yorkshire
I am going to be doing a cavity tie replacement on a house i rent out.
It definitely has CT failure. So i am looking at the mechanical driven fixing system as i have brick inner and outer, so quite solid.
The best price for 100 fixings are about £85 per 100. I need three boxes. The size is 8mm x 220mm.
Does anyone know where i can get these fixings a bit cheaper ?
I assume you've tried the obvious just asked for a discount. 3+ can be a price break for some things
Helifix, like twistfix make a similar looking product, but I cannot see a "cheap" Helifix kit, suppose it comes as what could be called a market leader??
I have seen twist fix and helifix. The thin joint ties are cheap, but i think they are designed for the light blocks. The normal ones which go into brick are £85 per 100.
Wall fast.co.uk have the best priced fixings at £70 plus VAT for 100.
I thought the ties were driven in using SDS. I will need to check this out.
Trevor, if you have a look at the Helifix site there is a good visual representation of what [Helifix] say there product can be capable of ???
There are also some neoprene ones that you might like to look at.
