mira connection is bottom left but there is a channel to allow a top entry pipe to come down through so if your pipe if coming out of the wall top left then you could stick a compression bend on it facing down and extend the pipe to connect bottom left, check google for mira and you will see fitting instructions
Take it you have an early sport mid 1990's.
The later sport can be used but isn't a direct swop as kirkgas has said you'll need to alter the inlet pipe.
And you'll useally find the cable willbe to short as the older model connections are at the bottom later it's at the top.
